Don`t laugh , but it was a Yamaha T80 ( Yamaha`s take on the C90 ....... I`m beginning to wish I hadn`t mentioned this now ...... ) .......
Maybe I was being a little harsh on shaft drive ......... There must be plenty of GS`s and Pans which have been to the moon and back mileage wise with no trouble ..... As Mr Alzero says , quality build and materials count , plus the option of being able to lube , grease and inspect without too much hassle ... ? ............ The little T80 had none of these , I don`t think you could even get inside the rear hub if I remember correctly .......... and I did thrash it around a bit , taking it up to Slaters on 150 mile round trips for Mirage spares ( which would always cause Richard some amusement when I rolled up on it ) , and buzzing up and down the A4 with the throttle held wide open , just sitting there watching 60 mph scenery go by ..... It would lift the front wheel on full throttle gear changes from first to second as well , what with the auto clutch re-engaging abruptly ....... I kind of miss it ........
My thing with shaft drive , and it`s just a personal concern , is just that I don`t like the idea of not being able to easily see , or inspect , anything which is directly connected to the rear wheel .........
