Hi Steve
not sure if the Range Rover is over or under engineered. Beautiful to drive, the interior is spectacular, the sound system is over the top, and the 510 hp is interesting. But, the list of known mechanical issues is long, servicing is stupid difficult (no access from underneath to any oil drain plug, to do an oil change have to vacuum suction oil out from the top of the engine....) parts prices are ridiculous., and to remove the engine the bloody entire body is supposed to be lifted off.
engine is now ready to be lifted out the front with the body still on. I now have about 30 hours in, some with the plasma arc, oxy acetylene, and Sawzall cutting out all the bent and obstructing crap, a lot removing stuff to get at the stuff that needs to be disconnected to remove the engine. Just getting to the engine mounts was stupidly time consuming. I left for last the unbolting of the torque convertor to the flywheel as to get to the access point into the junction of the engine and transmission to get a wrench on the torque convertor bolts, the active hydraulic sway bar that covers that entire area must come out, To get the sway bar out you have to remove a frame section and dis-assemble the entire suspension on both sides to free the sway bar. Just to get at the torque converter bolts, unbelievable...... i just finished all that and torque convertor is now disconnected, but it was an ugly job done in a home garage lying flat on my back.
I have a pile of removed plastic covers, formed aluminum shields, heavy duty skid plates, plus the hood, crushed front bumper assemblies, bent frame rails and thick sheet steel, crushed fender and fender well, radiator assemblies and mountings, etc,. etc.. towering in my driveway pissing off the neighbours. As the Range Rover with the toasted motor is the only vehicle I own with a trailer hitch, I can't even haul the trailer loads of scrap to the dump until the swap is finished
what I had not thought through until earlier today is that once I lift the motor out tomorrow and load it into my trailer and strap it in, I don't have a vehicle to pull the trailer to the shop doing the engine swap, bloody hell.... Will have to borrow a tow vehicle. I was threatening to fit a trailer hitch to the 79 Lincoln Mark 5 project but it is not quite finished, the muffler shop did a great job fitting a full new exhaust system which then revealed one of the exhaust manifolds is cracked, which i will deal with once the Range Rover motor goes to the shop.....
I did pretty much ruin the big welding blanket I Iwas using for shielding while cutting, lots of sparks and flames and hot metal flying around. I did manage not to set the garage on fire with the oxy acetylene and the plasma arc so did not have to break out the fancy fire extinguishers I have littered all around the garage.
ps the inexpensive Chinese made 50 amp plasma arc is the best cool new toy I have acquired in years, although I did have to add an additional 50 amp breaker and additional outlet to run the thing. I can think of lots of further uses for the plasma arc, although the oxy acetylene may still be more versatile. We will see how long the $450 Chinese made plasma arc lasts, so far it has worked pretty much as well as the name brand $3,500 plasma arc machines I have used in the past
Paul LeClair
