Maybe one of the engineers on here could comment on wear in the middle of the liners?
Ok, here you go. I use mostly a couple of different publications as support material for analysing piston failures. I don't remember ever seeing just one publication that would cover all of the already known failure modes.
This one is from a publication of Kolbenschmidt - Motorservice Rheinmetall automotive - when the scoring is on the middle of the skirts (especially on the pressure side):
Dry running/Fuel damage:
• Over-rich engine running
• Combustion defaults (misfiring)
• Insufficient compression
• Defective cold-start device
• Oil dilution with fuel
This publication is mostly suitable for big sized engines with relative low output if compared to the size of the engine, four stroke but both petrol/gasoline and Diesel engines. Some other publications are more suitable for engines with higher output per displacement.
The back side has bigger marks and certain shape on them because it is the pressure side, conrod causes a force piston being pushed against the opposite side of the rotation on power stroke.
I would have checked the oil if it smells fuel and/or if it has clearly lost its viscosity.
I would have expected more all around and/or four courner marks if the bore was too tight.
However, generally when analysing piston damages, in some cases the appearance is much dependent on engine and piston model.
-Jouni
