Did it come from the continent at some time?So having recently purchased this 1974 3c as a project, I was rather amused to see the novel duplex chain and spView attachment 105857rocket set up
As far as I'm aware Paul it was an Italian importDid it come from the continent at some time?
Those double chains and sprockets were a fad in the 70s, notably in France and Italy. Several endurance racers had them when more was better, very much like the triplex primary chains on our big Laverdas. The spaceframe triples had them.As far as I'm aware Paul it was an Italian import
It looks kinda of interesting and would definitely be a talking point, but I think if I decide to restore it a conventional chain and sprocket kit would be better.Those double chains and sprockets were a fad in the 70s, notably in France and Italy. Several endurance racers had them when more was better, very much like the triplex primary chains on our big Laverdas. The spaceframe triples had them.
JPX in France, Eric Offenstadt's company made duplex kits with nylon sprockets.
Yes it's a way off yet but that's what I'll be looking forHave to say I sorted a supersprox special (530) + smaller head fixing bolts + lock wire as an alternative to the standard solution
The factory space frame triples were equipped with duplex drive chains. Normal, cut-down SFC-style sprocket cover.The Benelli 900 SEI came from the factory with a duplex rear chain. Perhaps where you rear sprocket came from? What does the front sprocket look like? I would not think there is enough room under the cover for a duplex????
