78jotadave
MotoGP Engine Size Change in 2027
Yes — MotoGP will reduce engine capacity from 1000cc to 850cc starting in 2027, marking one of the most significant technical changes in the sport’s modern history
Key Details of the Change
- Displacement: Drops from 1000cc to 850cc.
- Maximum bore: Reduced from 81mm to 75mm
- Cylinders: Still limited to 4-stroke, 4-cylinder units.
- Fuel: 100% sustainable fuel, with tank capacity reduced from 22 litres to 20 litres MotoGPNews+1.
- Engine limits: Riders allowed a maximum of 6 engines per season (down from 7)
Purpose of the Reduction
MotoGP officials say the change aims to:- Lower top speeds for improved safety MotoGPNews+1.
- Reduce reliance on extreme aerodynamics, making racing closer and more overtaking-friendly Naked Racer Moto Co+1.
- Increase road relevance of the bikes, as smaller engines are more similar to production motorcycles Crash.Net.
- Promote efficiency and sustainability through smaller displacement and sustainable fuel use Naked Racer Moto Co+1.
Impact on Racing
- Performance: Power will be slightly trimmed, shifting the balance toward rider skill, tyre management, and chassis performance
- Aerodynamics: Front fairing width reduced by 50mm, nose moved back 50mm, and rear aero is homologated to limit changes
- Ride-height/hole-shot devices: Banned entirely to remove artificial launch advantages
- Data sharing: GPS data from all riders will be available to all teams after each session
