Laverdalothar
- Germany
Folks a bit of advice, please:
I think to remember that my 1000 SFC had a grooved ball bearing at the top and a tappered roller bearing at the lower end of the stearing head - am I right? I was a bit confused as someone who had his 1000 SFC restored recently said there are 2 tappered bearings, both on top and bottom of the stearing head...??
I have the assembly with the roller bearing installed, but turning the yokes from left to right shows a bit of a difference in the actuation: to the right, the movement is free, no problem. to the left, it gets stiffer/almost sticky at the end of the movement. You think this will change once the bike is completed and has done some miles or is there an allignement issue potentially?
thanks
thanks
