1000 Throttle Question.
jota2
Some times I should think before I open my mouth  :-X
I offered to help a friend get a late 3C of his running. It hasn't run for many years then when it did it ran on two cylinders. ( I did see it run once!!)
over all it has just been badly treated , shows 13,000 miles and it looks to be correct.
Sorting this is going to be a challenge, electrical splices on top of other electrical splices I found one wire spliced 5 times !
More to the point.... It needs the throttle tube. The switch seems ok (several splices there )   can just the tube be had somewhere?
Need to get it to sparky first, got the carbs freed up finally
Dave
yes, I have a couple of dozen here if you want one (Brisbane, QLD, Australia)
left over from Mikuni conversions, send me a pm if you want one
with your address
HTH
Red
