aebbern
- Calgary, Canada
I'm about half-way through a 4,000 km ride in the US on my 1200. All is going well except for one bizarre incident. When coming to a stop after a long part of the ride, my starter motor kicked in and wouldn't shut off. The ignition was turned off when this happened, and I'm pretty certain that nothing had touched or bumped the starter button.
Of course by the time I got all my luggage off and the side covers removed to disconnect the battery, the starter had done its job of draining my Odyssey battery. Spent a while checking all the associated starter wiring and connections - found nothing unusual. After an hour of this, I buttoned everything back together and it worked fine (amazed that the 9 yr old Odyssey still had enough juice to turn it over).
If this happens again, what should I be looking for... is it likely the starter relay shorting internally, or the solenoid?
Thanks,
Andy
Thanks,
Andy
