180 air filter refurbishment: foamy waffle
conrad
I've just called time on the disintrigrating foam of the air filter on my '81 1200ts (stock box, Fiammm 250x60 waffle slab thing). I've split open the plastic cage ok, but will any dirt bike air filter foam be ok to use do you think? it's not flow sensitive right? other than wanting it not mega tight foam, like pink foam prawns (yum).
I'm assuming getting a whole replacement will be too hard/pricey. correct?
air con filter gauze
cheap as DB, common as shit
cut to size, insert in same holder
cheers cam, that's real good of you. I gotta go to town one day next week so should be sweet, will let you know cheers.
Bugger. going to town means i gotta have a bath this weekend.
Pic of aquarium foam trial. I ended up using a slightly finer one.
Hag
Hey Conrad, make sure you purty up for those goodtime gals in the saloon....
I got it covered;
cheers bob, you've just given me an ace way to describe rural nz character. Saspirilla vs spirulina.
I have just had a go at getting the original 'foamy waffle' apart for my 1982 Jota 120.
I was successful, the two halves are stuck together with an 'Evostick' type glue.
I used my trusty mini-knife that is used for prising all sorts of things apart, it has a really thin and strong blade - cost? 10 pence at a boot fair.
I pushed the knife down the side as per photo and gently teased the two halves apart gradually.
The foam is totally shot:
salted
cheers chaps, Cam.
I was about to double it up there, but I also got a copy of Classic Bike today and there's this article in there right, by that Keith Nairn, and I see flow might be an issue so single ply it is. ace.
(that bloke looks a right dodgy do you not think? I bet there's a stilson in the red inside pocket of his diamond-shoulder leather jckt.)
yeah, the best knives are not just the posh ones aye. An old filleting knife makes a useful shed tool. Perhaps a knife thread would be a go?
ll do a test with a K & N filter
I put it in its holder, waiting for better days to test it on the road
Any opinion on adjusting the pilot screw (screw pilot air or screw for idle adjusting, I do not know very well the term to mean
vis de richesse ou vis d'air)
Xavier
