if the bore scope idea does not work.....
engine out is fairly quick, drain the oil, flip the engine over, and just pull the bottom engine case half, leaving the head/barrels/cam chain/crank etc. all intact. Not particularly easy but pretty quick as compared to a total engine strip.
any idea on the kms on this motor? What is the engine serial number? See below for affected engine serial numbers:
from Laverda Mania
* Note concerning the wrong bearing batches in 1979:
In 1979, like described in the "1000" chapter of this site, some bikes had been equipped with a wrong batch of bearings, meaning failures and broken engines.
Here are the serial number of these bikes:
1000:
- From the serial number 6204 to 6594
- From the serial number 6598 to 6603
1200:
- From the serial number 1519 to 1566
- From the serial number 1833 to 2533
http://www.laverdamania.net/roulementgb.htm
