38mm Ceriani damper rods and stanchions (internals) mated to Marzocchi sliders
  • Thread starter Thread starter silvo
  • Start date Start date
S
silvo
Guest
Has anyone done this before?
My Marzocchi forks are bent so I'm trying to find the cheapest way of sorting the problem by using what I've got. There's a lot of sense doing it, apart from necessity, because it resolves the caliper bolt issue and Ceriani internals are supposedly a better unit to modify with emulators.
You're using Ceriani gizzards inside Ceriani stanchion so there's no problem there.  So long as the OD of the stanchion is the same (give or take a few thou) there shouldn't be a problem there either. The only other point where Ceriani meets Marzocchi is the hole through the bottom of the Marzo slider. It only needs to be the right sized hole to fit the Ceriani damper rod bolt.
