SandPebbles
- Madison, CT U.S.A.
After being apart for several years, the engine was finally reinstalled in the frame of my '74 3C.
I used a method I've read about (and seen used) here on the forum and laid the engine on the primary side then
placed the frame over the engine. It worked a treat and took me about 60 seconds to complete.
I then slid four bolts through the four rear mounting lugs and placed nuts on them finger tight. I then righted the frame
and engine carefully. With the four bolts loose, I noticed quite a bit of space between the frame lugs and the engine
mounts. I tightened the bolts on one side only, and then measured about 1/16 inch clearance between the frame lug
and engine mount on the other side. I am referring to the rear upper and lower mounting points. I have not bolted up the
forward triangular plates or lower studs yet. It seems I can shift the engine in the frame 1/16 inch laterally depending on which side
I bolt up first. I may also end up stressing the frame lugs that I tighten last. While the lugs appear relatively straight, their width
is dictated by their welded location.
So my question is....is this extra clearance normal? The frame lugs do not appear to have been moved nor do the engine
mounts appear to be shaved. What is the general practice for alignment of the engines once it is in the frame? Any advice would be greatly appreciated.
