3C Horn Location
They come free when you buy new Voxbells. Not sure they are sold separately.
Dellortoman said:
Hey Piet. Do you also have the flexible laminated mounting blades that go between horn and bracket?
I think we had them made from some sort of springy stainless sheet, will check if they're still in stock.  Will let you know next week.  I can suppy new Voxbells if required (replicas these days, seem to work OK for a while...).
Brett said:
I've found they require a little bit of adjusting after a while.  Current draw is enormous, horn button and wiring usually not up to working 2 horns simultaneously, need to fit a relay.
Jod said:
I've a pair of new ones you can have if you like Cam
Thanks Jod. But I don't need them myself. I was just asking on behalf of anyone wanting to make a horn mounting bracket - they'll need the bit that connects the horn to the bracket. The last set of Voxbell horns I bought didn't come with them.
