3CL rear rotor has the same dimensions as any other stock disc used on Breganze 750 twins and all triples, excluding 750SFC rear and 1000SFC front. Early ones were 2-piece, both in solid or drilled, later one-piece and drilled, all will interchange. Even the RGS Corsa floaters will fit!
3C has rear drum brake...
Wire-wheeled Guzzi front 300mm rotors will fit Laverda wheels, very heavy though due to one-piece construction.
