3CL headlamp bezel removal?
There's 2 types, with and without screw.
Screw type is obvious.....  Screwless, just poke a thin screwdriver blade through the slot and push upwards.  The bezel is held by a spring clip.  Alternatively, you can insert a thin 'driver blade between bezel and housing, and gently pry the bezel off.
