1200ts
- USA - Riverside CA
As spring is here, pulled out the 3CL and noticed all the minor oil leaks are getting worse. Bike is 1976 with 29,000 miles and motor has never been apart other than chain replacement. Has IIS ignition and Jota exhaust. All the seals are leaking and front of head also leaks a little oil. Nothing major, no oil dripping off bike but I suspect in another couple thousand mile it will start happening. So it time to take it apart and fix the problems.
No the question is.............. as long as I am in there should I convert the motor to Jota spec? I have never ridden a Jota and don't know anyone that has one to try riding. The 3CL was on a dyno about 10 years ago and made 72.5 HP at the back wheel. It runs very nice and jetting and ignition are spot on.
So if I bump the compression ratio and install Jota cams will I like the bike better? What kind of HP increase would I see?
Or leave the motor as a 3CL?
Bruce
Bruce
