Freebird
- Surrey, UK.
Hi Everyone
I went to do a simple job of changing the brake fluid yesterday which turned into a bit of a saga when the rear one refused to bleed. The master is shot I think, it's drawing air in so it's time for a rebuild. At least it gave me the opportunity to take the swing arm out for a repaint - it's suffered from brake fluid spillage in the past.
I have used the search function and found a whole host of very useful information regarding rebuilding the master cylinder but am having trouble working out which size it is. I and am pretty sure it's a 15mm jobbie, only nothing in it actually measures 15mm so I wanted to check with you learned lot. The bore is 15.89mm diameter and the spigot that the bell crank acts on is 13.3mm diameter. I read somewhere that this should be 15mm for a 15 cylinder.
Also I have read that Motomecca or "Wolfgang" are good places to get a rebuild kit but the only Wolfgang I can find is a VW Beetle specialist.
Any help as always appreciated.
Glen.
Glen.
