Lyndoneil
- Towcester uk
I've stripped down the clutch side of the engine to check out the gear selector positioning, when I removed the crankcase cover the balance shaft came with it and sort of fell out.
Just wondering if it matters in what position relevant to the right piston being at TDC it should be put back in at. The workshop manual I have doesn't show the shaft existing as it's for the early ones, I'm guessing it does not matter, but I oftern guess wrong with bad consequences.
