Giles C
- United Kingdom
Hi again,
When I wind on my throttle gently my 500 will spin up nicely, but when I twist it aggressively the engine bogs, then will respond if I throttle back a bit.
The bike seems low on power (from memory of 20 years ago mind).
After reading up I have concluded it may be the accelerator pump. (The rest of the carbs are stock, no air leaks, standard plugs and air filter, standard exhaust. Plugs look pretty good, one cylinder slightly leaner than other but not much).
After reading the manual it mentions the pump, but doesn't say which way the screw should be turned.
Questions are:
Am I even right? Is is something else?
Which way should I turn the screw for more/less fuel?
Should I look for any other symptoms?
Thanks a lot
Giles C
Questions are:
Thanks a lot
Giles C
