The shoe return system differs from the 1st series to 2nd series Laverda drum brake, as does the adjustment procedure.
1st series has 2 springs located in the conventional manner between the shoes. 2nd series has only 2 small springs locating the shoes sideways to avoid having them flop around, the actual return spring is on the lever linking rod on the brake plate. US market bikes had a single spring fitted in the conventional manner in addition to the external return spring. Incorrect fitment of the 2nd series return spring is very common, with washers and nuts placed incorrectly on the rod. Sometimes a wonder the brake worked at all! Not at all harmful to replace said spring after 4 decades... valve and clutch springs have happily been replaced several times by then. Brakes don't seem to be so important. :
Assembling the 1st series requires a bit of force to spread the shoes over the locating posts, 2nd series is a lot easier.
The Lav drum brakes, especially the 2nd series, have recieved a lot of flak over the years, imho they can be made to work extremely well. All that is required is attention to detail, ALL slop must be eliminated and decent linings need to be machined exactly to drum dimensions. Still won't have the fierceness of a double disc, but more than able to handle emercency stopping. Choice of handlebar lever is critical, the stock late Tomaselli works quite OK. Condition of operating cables should also be checked regularly, again, no mistake to renew after a while. Old cables with high internal friction can ruin an otherwise well set up brake. Oil/grease can disguise shortcomings for a while, a new cable can be a real revelation! Again, 1000s of $ are often spent on engine and paint work, but old cables re-pressed into service... I see it all the time!
