Laverda SF
Pay close attention to the Back Plate cover on the starter clutch - It tends to come LOOSE causing the Dogs to missalign and chatter or jam.
The Rivets tend to loosen- Best thing to do is replace the rivets by tapping a drilling and use bolts or simply Tac-Weld the Back Plate to the drum.
If the Drum Rolling Cone is brused you can smooth it by placing the Drum in a Drill press and with true it with a flat file then polish it.
Of couurse if the Dog Rollers and springs are damaged you need to replace them.
Another items you may have to replace are the Case and Clutch Cone seals.
