R1220
- United Kingdom
Tony said:Absolutely, couldn't agree more Phil. It was Phil Irvings papers on crank phasing that set me to work on my Twin too.
If the stuck in the mud's at Triumph, BSA and Norton had listened to him in the sixties the whole British motorcycle industry may have been given a fighting chance to survive..... for a while at least!
It's all about conservation of momentum, he actually stated that 76? would be best for absolute power in a parallel twin, as piston A will be traveling at maximum speed on the power stroke when piston B effectively stops at the bottom of the stroke.
A 90? phasing gives the best compromise however between how fast piston A is moving when piston B stops on both the power and exhaust strokes.
Hence that's why my Twin is probably the only vehicle with a willfully eccentric 88? phasing. The original Laverda splines on a twin crank allow you to rotate in 4? increments so we went for a 'close to but less than' 90?.
T.
Hi
Very old thread but very interesting...
88deg.... That's why Morini with its 1200cc has a 87deg!
