Bike is an original 71/72 Breganze 750SF (Bought New here in Canada in 73 - Sudbury Ontario and one of 200 specifically shipped to Canada dissembled in crates to be assembled by prospective Dealers - To bad Honda eliminated the European Motorcycle Market here in Canada with the introduction of the $1100 Honda CB750 were the SF had a price tag of $3300 - I paid $1600 for a New SF over that crap ;o) but then who's to say "What a Thorough Bred is". I added the 3/4 Dunstall Fairing/Slater 2 into 1 pipes and Homemade Rear Sets, Bates Tail Light and some sort of Flexible Enduro Japanese Turn Flashers. Rear Fender is bobbed and upgraded the valve train to hit 8000rpm, plus Carb Jetting, rewired the Electrics and still use the VW Bosch Points: but the Borrani Rims and BREV Brake setup is Original.
A little off topic here but this is my Cockpit:
No Lucas Prince of Darkness Ignition Switch here but there is a Chronometer - Which reminds me to Go Home.
That bike and I have been through Hell and High Water for the last 45 years.
Like my Carrier - Handles a Fat Ass Fraulein with a pillow or 2x's 24 cases strapped in ;o)
As far as functionally goes, from my experience, the SF "Super Freno" leading shoe BREV Drum Brake is not as good a Disc's, in fair weather, when repeatedly hauling down from high speeds under race conditions as they tend to fade over being repetitively applied from speed but are definitely Superior in the rain and can say they wear with less maintenance then Discs. Put it this way, the SF BREV Drum Brake is very capable of throwing you over the bars. It's the same Brake and Rim used on the 750 SFC and early 3 Cly's. Other then Grimeca crap the SF Leading Shoe BREV Breganze Brake is the biggest Drum to be had on a Motorcycle and they're light.
Believe me, in emergency applications under every day use, they are more then enough to be reliable and last forever if you keep them clean, blow them out occasionally and maintain your cables. Depending on environment, clean and grease the Pivot Cams every 5 years and the Axel Bearings while you're at it.
There's a little hands on experience when adjusting the SF BREV Drum Brake were you set the shoes to clearance against the drum when applying the Cable - Say .010 to .030" at the drum when you got it right without draging the other shoe - Are you that good It's automatic to me after all these years .
Them are STD 18" Rims, could you imagine how short the spokes would be if they were 16" rims - LOL
I know a lot of our members hate my 3/4 Dunstal Fairing as it hides that beautiful SF Mill but I would not trade it for anything as it brakes the wind on long cruizes, keeps me dry in the rain and only weighs a pound.
If you want to see the Engine here it is:
