new sprockets these days are a tight fit but are a tight fit mainly because the tip of each spline needs a small chamfer
don't touch the splines themselves, they are a great fit as is
I use a pencil grinder to just remove the tip off each spline on the sprocket itself, just a touch, you are only removing the sharp edge, it fouls on the root of the mating spline on the shaft
they are then a perfect fit, tap on with slight force only
been doing this for years now and I generally tip each sprocket we sell as well before we post them out
HTH
Red
