right again Phil
racing model/2 pick ups
what you don't know is that I bought my system from Ernie before you had prototyped and arranged production with him, and mine was for a Norton Commando, he was a little reluctant to sell to me when he discovered what I was doing (although he had previously supplied a system to Dave Minton/Slaters, which was surreptitiously nicked when at moto Laverda)) and of course there were no engine shaft bits that were any good to me, these were made by my long diseased sidecar pal Ray Wilson, and (at the time) the Commando system was offered with one pickup (standard road /touring) or two (for racing), naturally I opted for the later, as you did for all Laverda 750 models (again no surprise).
I never did run the bike with this system fitted, because I later discovered that the Commando did not have as big a full advance as the standard Laverda points set up, so points/coils it was.
Interestingly I am about to convert my 350AJS to 12 volt electrics (it already has a three phase Lucas alternator) using a Norton rotary/Ducati reg/rect and I am going to leave the ignition as points/coil due to the low mileage that I will do and supreme simplicity of a single points set (with spring ATD) a spark plug and a coil. why am I doing it? because as installed there is no voltage regulation, and the ammeter has to be constantly monitored, with one alternator coil being used for ignition and stop lamp, a second coil if pilot lamp and rear lamp is on and a third when using headlamp,
British bikes?... it surprises me that this industry lasted so long on our shores it should have failed earlier.
the bare rear alloy (cast) wheel on a Laverda has five components (not counting the wheel itself) and works very well, the AJS bare rear wheel has eighteen (not counting the hub, cush drive, its cover, 40 spokes and a rim) and doesn't work very well.
so you have Laverda, six components
AJS............forty bleeding three!
or five over eighteen if you prefer to be more realistic and leave out the spokes.
