Simon Yates
The status of the ignition points on my 1969 750 are as follows.
Oil pump gear - moved 3 teeth relative to the crank gear to retard the ignition.
The range of adjustment (outer set) is now from 18 deg BTDC to 8 deg ATDC.
Set the outer timing to TDC then establish the limits of inner set using eccentric adjustment it is 14 deg to 32 deg ATDC.
Why is there this descrepancy between the inner and out plates which do not allow the inner points to be set to TDC?
I could vary the points gap or abandon the eccentric and extend the two slots slightly.
