Spub said:The difference between the 1974 SF2 I had and my 1974 SFC are stark, even though they have the same engine. The extra work that went into the SFC to balance it makes it a different bike, as far as vibration goes. I'm not saying it does not vibrate, but compared to the SF2, it is Bevel Ducati like in smoothness, even with its lumpier cams. So while phasing has an effect on vibration, tolerances may have as much an effect, if not more....
Spub,
The engines are based on the same design and share a few components, but that's where it ends.
The SFC cranks were actually balanced differently to the cooking bikes. While the racing dept. set its focus on reliability and low bearing loads, they cared nought for rider comfort! The road bikes were balanced for comfort and took slightly higher bearing loads for granted. Theoretically, a SF engine should run smoother than a SFC.
A teacher friend (university level automotive technic) worked out ideal balancing factors for the Lav twin. Measuring both SF and SFC crank weights/balancing confirmed his calculations. SFCs were balanced to around 58% while road bikes were 70%, more in line with common practice on upright parallel 360? twins.
Totally agree, the SFC engine is a delight. The way it spins makes the mind boggle. The gearbox also helps a lot in keeping it spinning happily. As much as I loathe the complete bike, I'd love an SFC engine. Stick it into a nice SF2 chassis and have bags of fun!
