mikeb
- new zealand
Back tyre (bt46) of my SF2 touches the ground when on the main stand. There is some wear in the stand’s bushes tho the frame lugs/holes look fairly ok. But additionally my rear shocks (old konis) are 330mm centres, not 355mm so it should be well clear.
Is the stand right? See the pic - doesn’t look bent to me. It measures 240mm from pivot centre to bottom of the foot but I can’t find firm data to check this. I have seen some numbers from 230 to 270mm height, as well as references to some stands (GT?) being 20mm too short. So…
1. does anyone know the correct height for the sf/1/2/3 stand? I’m tempted to cut it near the feet and extend it a bit.
2. the sleeve around the bush is clearly worn (pic3). Would you weld that up a bit and file it out? Or not worry about it?
Thanks
(ps – I didn’t paint it!)
Thanks
