750SF3 Seat
Well I know an SF3 seat wont fit a triple, because I bought one by mistake.
It was the hinge positions which were different if I remember correctly so it follows that the triple seat hinges will be in the wrong place for the SF3.
Back hinge and locking pin will fit on a triple frame, front hinge is to far forward to line up.
Long bolt will work as a makeshift solution for the front hinge. IMHO the seat pan is tad shorter than the triple version, but a lot comfier.
HTH
Gerald
and.................. if you look closely at the frame of most SF3's, well at least the ones stamped SF2 !  you can see where luigi ground off the seat spades and welded on the hinges, then touched up the four areas with a rattle can, a ten year old could do it better.
