Thanks, I'll experiment some more asap.
Tonight I installed a set of new #135 mainjets, instead of the #125 that was there after we tried a set of #110 which were way too small,a dn it ran terribly.
The #125 faired a Little bit better.
And tonight the #135 went a Little better stil.
So, inwards with the idle mix screws to compensate not to overfuel all over, and it drove a bit better still.
The problem is now, that it cannot pull on quick gasgiving, but if you give gas slowly, it picks up and goes all the way to 8000.
Well, we don't actually know, because the tacho cable broke. A new one finally arrived today. Great.
In first and second gear, it flies forward compared to earlier. 3,4,5 not at all, only when giving gas slowly.
So, problem are the same, but lesser and lesser.
A long pile of various main jets and pilot jets are now on it's way.
Also, we took a closer look at the dissapearing low beam. Sort of the guest of the week, and it turned out to be a few Things: some green corrosion in 3 electrical multiconnectors in the headlamp, and a slow relay plus a near broken wire on one of the supplies to low/high beam. All fixed now.
My friend installed a new manometer for the two interconnectes rear dampers and a new front tire plus inner tube. We fine adjusted the pressure to 32 front and 37 rear which felt fine.
I think we are getting nearer.
We have soem nice 40mm downtubes and big bore collector ready for installation in a few days.
My friend will install a new LED headlight into the old headlamp housing, which should minimise amp usage and enable low beam daylight driving (mandatory now in Denmark), plus actually cast a light beam
We'll see how that fares an dI will comment on that here as well.
I'll report back on how it fares asap.
Kind regards,
Jacques
