Air gap for cerianis with emulators
Cosi
Kingscliff
Before you all attack me and tell me to search I have and I can't fine any definitive info, so emulator and springs out staunchions compressed what is the reccomentadion, from what I could gather 110 to 120mm, thoughts, I prefer a stiffer front, for a 3cl
Racetech say:-
"Common Oil Level is 130 - 160mm (Fork Spring out, chrome tube at the bottom of the stroke, measuring from the top of the oil to the top of the fork tube). Oil Level Tuning Range is 100-180mm in general. The Damping Rod must be covered with oil at full extension. Also, be sure not to exceed the maximum oil level as the fork will run out of compressable air space and it will inhibit full travel."
Shajota said:
Racetech say:-
Just be sure that that figure is for an SF, which has shorter staunchions than a triple.
