G'day Cheesy
My local dynamometer bloke and I did a bunch of dyno runs with my Jota using a range of main jets. My bike is a reasonably typical Jota - 4C cams, high comp pistons, 39/36 valves, original air box and low restriction filter, Jota exhaust.
We found that if you go above #135 main jets on otherwise standard carbs (32mm PHF Dellortos with AB265 needle jets), it won't flow any more fuel at wide open throttle. Just for interest, we did a run with no main jets at all and fuel mixture was similar to the 135 mains (around 11:1 I think). We deduced that the needle jet was limiting the fuel flow at WOT.
If a previous owner of your bike fitted 145 jets, then he may have been using a methanol mixture and could have fitted a different needle jet too. Probably worth checking.
Standard settings are:
Main Jet 118
Needle Jet AB265
Jet Needle K1 middle notch
Slide 60/2
Pilot (idle) Jet 55
Starter Jet 70
Float Valve 250
Float Height 17.5 - 18.5
Idle mixture screw 1.5 turns
Accelerator Pump 4cc/20 strokes
Modern unleaded fuel is a bit different to the leaded stuff that was around in the 70's, so you may need to run bigger jets than 118.
I'd go with Grant's suggestion of 125. That's what my Jota ended up with after our dyno session. It actually ran marginally better with 120 jets (made about another ? HP) but was a little too close to running lean for my peace of mind.
Of course, there are all sorts of other variables such as cam timing, air filter resistance, general engine condition. Not to mention air pressure, temperature and humidity. So your optimal jetting may end up different to mine.
If in doubt, give it a run on a dynamometer with a sniffer up the exhaust.
Cam
