M
Morizzi
Guest
Hi all,
I'm slowly sorting out the issues with the Alpino. I've got a bit of dodgy wiring in therefrom a PO and I'm trying to sort it out. Went to my copy of the manual but it is missing the wiring diagram. :
Anyone got an electronic one you could email me please?
What clown would run a +ve feed in black wires? :
I don't know if that is standard but that's what I've got. Lucky I didn't burn out any wiring. I just naturally assumed that black would be negative. The headlight shell is just a pile of spaghetti.
I found that my ignition switch wasn't doing its job but I've managed to fix it, temporarily at least.
It was all gunked up. I tried to pull it apart but the bakalite just kept breaking so I decided to stop that. :
Anyway I degreased the snot out of it then gave it a dunking in phosphoric acid to clean up the contacts then rinsed well and its working like a charm, for a while anyway.
Thanks in advance if you have the diagram.
Rod
Rod
