and also sold by Gjis van Dycke in Holland, but at eye watering cost, I have never had a drop of oil leak from mine, bought and installed while I waited (and was on holiday) in Holland, he was reluctant to allow me to keep the original.
SJCE supplied starters for bikes that were not Laverda orientated, these were brought to the UK and most got modified to incorporate an oil seal that the intended bike did not get, in the main this was done very well and worked well, there were some that did not get the seal installed (initially) which was an error quickly corrected,and others that did get the seal, but leaked, also quickly corrected. Not everyone solved the problem and at least one known reprobate reverted to a Bosch following a "custom" rebuild of that unit.
For classic cars, Jaguar, Rover, plus Perkins etc, there is a modern starter kit available which uses a much smaller unit and a small offset bolt on gearbox, they are not costly, it might be possible to adapt one of these to fit a triple, and more importantly, because of supply issues a Breganze 750.
