I?ve been doing some research on getting a run of Zane clutch cush rubbers and rear wheel cush rubbers manufactured.
Most of us with Zanes are not aware that there are cush rubbers in the Zane clutch basket, cos in the spare parts manuals there are no breakdowns and no part numbers. Same sort of setup as the Breganzes, but different sizes.
I was asked some months ago to fix a rattly 668 clutch, and on breakdown the rubbers were shrunken and hard. Based on the density scale used for rubber (what was the name of the scale? Not Rockwell..) they were a 90.
A new cush rubber for a Breganze measured 70. The 750S samples I took in measured about 80. The other air-cooled zane samples were above 85.
The rubber type used when exposed to above 100 C hardens rapidly and shrinks. Given that the air cooled run quite hot, up to about 125 C(?), this would explain the hardness as compared to the water cooled motors, which is limited to about 90 C (?).
So, in the aircooled motors would this lack of absorbtion in the clutch transfer to drivetrain/gearbox issues that are more pronounced than the water cooled motors?????
Thoughts, debate ect would be appreciated!
Regards, Greg
Regards, Greg
