don't like them, don't look right, not set up to run parallel with the fork legs, just look wrong to me
bit more thought and can do a far neater job then those units
is why I make my own adaptors
fair play ,just wondered not seen them before, but you don t sell them anymore Red do you? re any legal repercussions.I can always get my Spondon ones copied .
Similar to the ones I had made. Certainly not as flash as Reds, but work OK. No issues over the past 12 years since fitting the 4-pots. Quite easy to adapt for differing disc diametres, I specified mine without caliper mounting holes and drilled them accordingly. Next version will be a little nicer.
i know these adapters from my guzzis, but first you have to decide what diameter your discs will have (guzzi 300/320)
it will give old bikes a"wild technical" higher sophisticated look.
after years of experience i prefer using a better pump up on the bar/clip-ons. that will work too.
