redfox
So, I've spend 2 days trying to loosen the brakelight switch bolt on top of the rear brake master. Likewise on the rear caliper itself. No visible corrosion, but not moving it certainly is.
I tried to spray them with anticorrosion/screw loosener spray every 4- hours, combined with a bit of heat (not too much) from a heatgun on the low setting, and I've done this for 48 hours now. Not giving in at all.
I'm a bit afraid of breaking something.
Any good suggestions?
Reason for doing this is the 32 year old rear brake hose needs to be changed, as it's beginning to free some nice Black rubber material on the inside.
I have always changed the brake fluid every year for the last 12 years, but this time, it's stuck. Bleed screw too.
Kind regards,
Jacques
Kind regards,
Jacques
