I have a plan to eliminate the loud wind roar I get once past 80kph. I noticed on the last expressway ride if I held my hand over the large gap below the dash instruments it suddenly became a lot quieter. It looks like air flows around the new bigger windscreen sides and into this area causing this loud sound. But I cannot block this area as that's where the ignition key is, but I can add a couple of panels up each side of the Navigation tower and forward scribed against the new larger windscreen. I bought some very stiff cardboard to experiment with and cut and scribed 2 pieces approx 200mm x 300mm against the windscreen and added 4/ 20mm bulldog paper clips to hold them in place. If this works I will remake them in perspex so I can still see the speedo and tacho easily in daylight. We have a week of rain forecast so after that, I will test this out, plus check to see if the speedo is fixed and how the newly reconstituted full rear suspension travel works out.
