Seeing tiny drops of oil only just dribbling from the underside of the rockers at idle speed isn't exactly confidence-inspiring. This oil mostly sort of finds its way to the valve tip... the rockers and cams are almost dry after only about 30 seconds. I don't subject my valve train to such abuse if I can avoid it. It is only at higher revs that oil flow increases. Even then, pressure still isn't sufficient to squirt oil to the cam lobes, but is more or less splashed/flung around by the oscillating motion of the rockers. The additional oil feed from the gallery above the cam at least delivers a couple of drops almost directly to the cam, may be the decisive drop between OK or knackered.
Reckon there weren't many traffic lights in late 60's Italy...
