Spub
Being obsessive about balanced carbs, I have been fiddling with that bell crank balancing mechanism on my Jota for the past two days. There must be a better method than the one I have been using, which is to loosen both adjust screws so there is no contact, adjust the middle carb to one of the outers at idle with the idle screw, then adjusting the other outer to the middle, then tinkering by raising to 2500 rpm and making sure all three rise together, which is a bitch.....the twins are MUCH easier......so who has a better method....if one exists....
