Laverdalothar
- Germany
Regarding the repeater lamp: that does not exist that way on the 1000 SFC, as there are 2 actually, both in line with the left or right turn-signals (the arrow-lamps on the dash). So you can leave that cable off, it is just there as RGS has a different dash and RGS and SFC share the same wiring loom.
regarding the Alternator: 2 cables can be put together, the 3rd goes to the headlight switch and from there to the battery. This shall activate the 3rd phase only if headlight is on to safe the battery from over-cooking, as the SFC-battery is normally a bit smaller than the one from the Jota or 3C (which were actually the same as used in the Fiat 500...).
As you will always ride with lights on I suppose, you can safe the switch from the high voltage coming from the 3rd phase by re-wiring the 3rd phase directly to the battery. I assume you will need to make a wire though connecting from the fuse-box to the wire that goes to the headlight switch, else you will be lost in darkness I guess... haven't done that modification yet with my bike, but I assume that would be the route to go.
Maybe Piet can confirm, he has done it several times and also on his RGS I think.
Also I would consider putting a bigger wire from plus of the battery to the headlight, feeding the headlights via a relay that you switch with the original headlight cable. This gives roughly 30 - 40% more light output... (measure what Voltage you have on the battery and what comes to the headlight and the difference in % is roughly what you gain... f.e.: if Battery is 12V and headlight is 9Volt, difference is roughly 30% (based on the 9V), so you will see roughly 30% more lumen on the headlight with the bigger wire and the relay in place).
