Electrickery is my worst subject. I want to check the output of the alternator to . When I check at the battery I get less than one volt rise. 12 to 12.5 - I did charge the battery and its now at 13.2 V. I'm not sure what the output should be. I also want to get a feel for how the voltage regulator is working and what about the rectifier? Any simples checks I should do for each of these components to verify they are working?
This is for a 1979 1200, however, based on the engine number (5509), The engine is a 1977.
I read in another thread that the voltage coming off the alternator would be around 80VAC - would I check that at the rectifier?
Thanks
Thanks
