Rockitdoc
- Fort Collins, Colorado
How does the battery tray mount on this machine?
Thanks for any help in advance.
S
S
Laverdalothar said:Hi Scott,
You will need to take the swing arm out. That sounds harder than it is, but will safe you from lot of trouble to get the nuts on the bolts.
There are 2 angled and drilled plates welded to the frame where the tray is mounted on, the lower one is on the left side, the higher one on right side. for mounting the 2 bolts through this angled bracket, the swing arm needs to go out and then you have easy access to the bolts for mounting the nuts.
HTH
