itsagas
- Newcastle Australia
I'm restoring a 3cl and tried to install the front end today and all went well until I attempted to install the top yoke nut.
It wouldn't fit as the steering stem was out by about 3mm.
Pulled the front end off and measured up to find a discrepancy of 3.5mm between the bottom of the stem to the top of the steer stem.
I used the straight stanchions as a guide.
These are my questions
1, is the bend more likely to be in the bottom yoke or in the stem?
2, what is the best fix if only the stem is bent?
3, what if its in the yoke?
4,has anyone had any luck straightening stem and what is best method?
4, if its the bottom yoke?
Dean
Dean
