Brake and Oil line suppliers
71Laverda750SF
I did a quick search on the forum and only came up with one thread (the way I worded it may be why) dating back to 2011 and it only covered the UK.
Looking to replace the oil cooler lines along with all the brake lines on the 120 Jota. I figure braided stainless, maybe covered in black rubber.
Suggestions.
Thanks
Clay
Suggestions.
Thanks
Clay
Clay..when I did my brake and oil cooler hoses I went to a local AeroQuip hose shop and they made them up in less than 30 minutes. Parker also sells the hoses.
Use this link to find an AeroQuip dealer near you.
http://www.eaton.com/Eaton/ProductsServices/Hydraulics/HowtoBuy/AeroquipExpress/Stores/index.htm
And a link to find a local Parker hose shop.
http://www.parker.com/portal/site/PARKER/menuitem.98bf0856fd643a238c23b35b8320d1ca/?vgnextoid=894fb34395d2b210VgnVCM10000032a71dacRCRD&vgnextfmt=default&from=parkerstore&citype=ParkerStore
I bought some black covered stainless brake lines from Wolfgang. As always, reasonable price, Correct length, just bolt on ;).
He no doubt has the oil lines too, but for them I just bought some Hydraulic hose from local farm supplier and screwed on original fittings. Took original hoses to match up. Shop owner was surprised it was hydraulic line and used these screw on fittings, but obviously no drama not under any real pressure.
