M
Morizzi
Guest
I'm with Cam and Simon. Many A2 and A4 stainless are not much stronger than grade 1. A lot depends on the torque chart used. Many I've seen give A2-70 as typical of 700 but a minimum of 500. That's a big variance.
At times like this I ask myself 'whats to gain and what's to lose?' :
Stainless isn't significantly lighter but its weaker and shiny. 8.8 isn't shiny but its stronger for similar weight. When I'm trying to brake really hard and wash off 50kmh do I care more if they are shiny or strong? This is why I'm on the No side.
Because I like to stand on the pegs to stretch my legs I only use 8.8 for those bolts too. Stainless is out.
You need to be careful using stainless into alloy too. It is more noble than steel so the difference between it and alloy in nobility is greater, hence greater risk of electrolysis. Not saying it can't be done, just saying you need to be careful. If you don't understand the difference between active and passive stainless or what compounds can be used to insulate the 2 types of metals then google is your friend. I stongly recommend you DO NOT use nickel or copper antiseize.
I'm more paranoid than most on this as I work in the Marine industry on alloy boats. Steel shafts, alloy hulls, brass propellors, all in salt water. They are little current factories. They are welding themselves together even as I sleep.
Rod
Rod
