Brembo brake info.
Hambo
Hi, I'm modifying the front end to accept brembo calipers from a 996 ducati...the ones that are 65mm between mounting bolts...I am trying to order new discs but need the swept area of the pads for the order to be accepted...I haven't rebuilt the calipers yet and thus have no pads to measure the depth of contact...can anybody out there enlighten me please? Thank you.
https://store.bevelheaven.com/Brake-Related-Parts/Brake-Adapter-Set-F08-to-65mm-Mount-for-280mm-Rotors/
may help, may not
Thanks for the replys all, but I'm ok with the mounting points, it's the disks that I'm ordering from the UK require the swept area of the brake in order for my custom discs to be made... so it really is the height of the pads that fit into a Brembo caliper off a 996 that I'm after... and even tho the company MAKES discs for 996's they want me to supply the information...
Surely if you are replacing the std setup by just a move to different calipers, ie F08 to the 65mm 4 pots then the disc diameter will be exactly the same as the one you are replacing, ie 280mm for a 3cl/jota.
That's pretty similar to what I'm doing but I've reinforced the headstock and have put 996 Showa forks on but want to keep the original wheels..forks are lengthened internally a bit so I'm only 15mm off what it was with the old shocks...so I needed a 320mm diameter rotor with 13mm offset and a 80mm center and PCD of 101.5 for the original wheels.. phew! Getting some via HPS / ISR but they needed EVERY detail. Got a great email from this site and was led to this site which has awesome tech drawings!
http://www.oppracing.com/images/cmsuploads/Brembo/OEM_Schematics/oppracing%2020-9230-10_20%20brembo.pdf
Dunno if it will work but its keeping me occupied. I have all the original parts and can put it back if need be...plus it'll be stronger due to headstock mods.
I have made a similar mod to my SF2 (and my Duc), and could not find suitable discs anywhere.
I ended up geting a pair custom made by Menani Racing in Italy.
The quality is good, and the price quite reasonable, but delivery times were long.
Dale
Sorry, mate.
I lost my work space and had to put the (still unfinished) bike in storage until I can find another place to work.
No photo's at this time.
Dale
If they're likely to be the same as the earlier 916-99?' I can measure mine (I'm just not exactly sure what model Duke of the 916-998 series they came off), but 320mm Brembos from one of these bikes. I am happy to make some measurements if you like - what specs do you need? Distance from centre off inner and outer swept areas?
I'm keeping my stock Laverda disc brake hub and intend machining up adaptors, but I have the luxury of a much wider front end to fit it all into.
