Brembo F08 question
Never paid attention on any F08s I have rebuilt, and they always worked fine.  Make sure you lube the seal with the white grease provided, and grease and replace the O ring between the two caliper halves and you'lll be fine.
The seal itself is square, the groove has a slight taper.
Do check all corrosion has been removed from the groove, often over-looked as especially the edge nearest the "outside" of the caliper, where you cannot see it, is afflicted, need to scratch around with a hook-shaped implement to get at it properly.
These work really well for that groove http://www.ebay.com.au/itm/10-Brass-Wire-Rotary-FLAT-BRUSH-Cups-Fits-Dremel-Tools-/151014453503?pt=UK_Home_Garden_PowerTools_SM&hash=item232929b0ff
Thats him!  I felt a tiny raised edge
Thanks Piet
I wouldn't use that. Caliper material is very soft and those brushes are too agressive. I wouldn't even use wire wool by hand.
Soak and use a washing up pad, gently. Those calipers are going to become rare.
Not going anywhere with that method, Paul.
Might be ok for the outside, but the corrosion I find in grooves sometimes requires heavy artillerie to shift.  Very hard and stubborn, all because the Brembo guys were too skint to anodise the caliper bits completely.
In comparison, I recently re-built a very old and neglegted pair of Lockheed calipers for a MV or Ducati.  Only needed a short spell at the parts washer, they came out like new, no corrosion at all!  These were completely coated, inside the bores as well as in the grooves.
I use an angled scraper (sort of like a dentist would use) to scrape out the groove that the seal fits in. You can be sure the crud is in the least accessible area. I do this as a matter of course now because even with new seals and pistons the caliper will leak like an SOB if the seal cannot seat in the groove properly.
