Brembo master cylinder versions
Basketcase
What is the difference between Brembo master cylinders with the cast-in allow reservoir and the plastic reservoir version.
I can already see that the plastic version has a grub screw adjuster in the lever that the alloy one does not.
Do they use the same piston and seals?
Rob
Main difference is the lever and the adjustment thereof.
Same piston and seals for both.  The cast item was available in one size only afaIk (15mm, actually 15.8 ), the later type also available in 14mm.
