Rob
- Midlands, UK
Set of three P08 (or more accurately P2 F08 N) 38mm brake calipers & EBC pads - £390 or £140 each plus postage.
Stein-Dinse are currently advertising new calipers at €196.87
These are unthreaded as fitted to Marzocchi forked triples and 750 twins.
Freshly cerakoted castings with new seals, teflon pistons, bolts, stainless bleed nipple and pins.
Fitted with new EBC FAO18V semi-sintered pads suitable for cast iron discs.
The cerakoting was carried out by the chap who used to do the same job for DucatiPaddy so the finish is excellent. I had a number of calipers and master cylinders prepped & coated for a rebuild and decided to include my stock of spare calipers at the same time.
Seals were fitted using the correct Brembo grease and pads/pins lubricated with specialist 'Proslip' grease.
The black foam brake pad spacer is for transit & must be removed before fitting.
